This command disables IPv6 route redistribution of the specified type into IS-IS.
| area_name | Specifies the IS-IS router process for which route redistribution is disabled. |
| route-type | Selects the type of export route to disable. The valid route types are: direct, ospfv3, ospfv3-extern1, ospfv3-extern2, ospfv3-inter, ospfv3-intra, ripng, bgp, and static. |
All types are disabled.
None.
The following command disables RIPng route distribution into areax:
disable isis area areax export ipv6 ripng
Support for BGP was added in ExtremeXOS 12.6.0-BGP.
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
